AnotherGamer
Jul 20, 2023Aspirant
Trying to add AdBlock Lists in DUMAOS.
So I am trying to add adblock txt files I got from Github. This type of lists and I've tried domain only lists But none of them can be added. The blue bar would go from left to right, as if...
AnotherGamer
I tried to add Default list but nothing happens?
- Netduma-FraserJul 21, 2023NetDuma PartnerI think they're too big for the router and it's got itself into a weird state. Factory reset, add the default list we've provided, that should then work. Then from there, if you add files that are under 5Mb it should work without error.
