hoopaughh
Dec 18, 2019Follower
trying to log in my dashboard
how to log in to access dashboard and how to place stuff two 2.4gz and 5 gz
Netduma_Alex
Dec 19, 2019NetDuma Partner
Login to the dashboard by going to routerlogin.net
Enter the username and password that you set up when the router was first installed
If you're using smart connect, the band choice is handled automatically
