boomerx01
Aug 28, 2022Aspirant
TWO XR500 for whole house coverage?
I have an XR500 Configured with QoS, etc. - but I have a 3,000sq Ft two story house and need more coverage. I have a hard wired connection available downstairs, can I run ANOTHER XR500 in AP mode so...
boomerx01
Sep 01, 2022Aspirant
Were you using a wired backhaul? It seems certain models don't support this function?
Sep 01, 2022Guru - Experienced User
No, EX don't support wired backhaul.
- boomerx01Sep 01, 2022Aspirant
Thanks - recommendation on which one does?
- FURRYe38Sep 01, 2022Guru - Experienced User
Extenders don't support wired backhaul from what I understand. Wired backhaul is mostly designed into NGs MESH systems, Orbi and Nighthawk MK.
One way to use two XRs via ethernet would be to make the 2nd one in to a AP configuration. You probably use same SSID name and password on both however wifif channels would need to be set far apart on each unit. Or use a different SSID name on the 2nd router would be recommended. Same configuration would apply to a EX extender in AP mode that would be ethernet connected to the main host router.
