bevant
Oct 18, 2020Apprentice
UI issue but Netgear tech support is the dumbest in the world.... CONTINUATION
In the original post, I mentioned that in the XR500, if you plug a cable into port 4, in DumaOS, it shows up as Port 1. Called Netgear stupid support and after THREE changes of modem, the problem...
- Oct 19, 2020.66 is just security updates from NG so no changes on our side. It's not fixed in the current build but the fastest way to get the fixes would be to upgrade to the 3.0 beta.
Netduma-Fraser
Oct 19, 2020NetDuma Partner
bevant
Oct 19, 2020Apprentice
It's ok. As long as I know when it's going to be fixed...I don't want to go to Beta...Netgear's wasted enough of my time, not about to do more of their work for them for more angst.
Thanks Fraser.
