bacevedo
Feb 07, 2019NETGEAR Employee Retired
Ultimate Speed Guide for XR Routers
This guide will help you to maximize your bandwidth speeds with your Nighthawk Pro Gaming router. We recommend you only follow this guide if you believe your speeds are lower than they sho...
bacevedo
Feb 08, 2019NETGEAR Employee Retired
Hey FURRYe38,
Thanks for your response and yes, Double Nat can be an issue. We have a great NAT Guide to help out.
Thank you for pointing out about the XR450. Unless they specifically state overwise, my guides will work with the XR450 and XR500/XR700,
but I'll make sure to include the XR450 fans going forward too. :)
Best,
Ben
Feb 10, 2019Guru - Experienced User
And maybe you can change the title subject line of this post to include the XR450 as well.
Thanks.
bacevedo wrote:
Hey FURRYe38,
Best,
Ben
