bacevedo
Feb 07, 2019NETGEAR Employee Retired
Ultimate Speed Guide for XR Routers
This guide will help you to maximize your bandwidth speeds with your Nighthawk Pro Gaming router. We recommend you only follow this guide if you believe your speeds are lower than they sho...
XxDarkxEchoxX
Feb 24, 2019Aspirant
If your speeds returned to normal then you have achieved the objective of getting full speeds. However, your QoS is no longer setup optimally. We recommend you now configure this to get the best congestion elimination setup for your network.
Where can I find the recommendations to configure QoS for my network. Thanks!
Netduma-Fraser
Feb 24, 2019NetDuma Partner
You can follow this guide: http://support.netduma.com/en/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos but then to fine tune it specifically for your connection I would recommend following this guide: http://support.netduma.com/en/support/solutions/articles/16000074717-test-your-connection
