bacevedo
Feb 07, 2019NETGEAR Employee Retired
Ultimate Speed Guide for XR Routers
This guide will help you to maximize your bandwidth speeds with your Nighthawk Pro Gaming router. We recommend you only follow this guide if you believe your speeds are lower than they sho...
IDdrew
Sep 06, 2019Aspirant
The top of this "guide" need explain the many many factors encompassed by the term 'speed' [and 'latency' also explaining the different flavors of traffic moving differently]. There should be a light primer on peering and bgp in the post-netneutrality world. 802.11 ought be avoided. Why is there no treament of client NIC?
links to DSLreports and SpiceWorks would be helpful or to actually helpful tinkering information.
- Netduma-FraserSep 07, 2019NetDuma PartnerIt is just a specific guide for getting full speeds with this specific router, what you are talking about would only serve to confuse people who just want to know what to do. This is not a router meant to have every technical option, it is meant to be a user friendly router than anyone can pick up and use straight away.
