tunkul
Apr 22, 2025Aspirant
unable to access router admin page due to https
Trying to hit routerlogin.net keeps switching over to "https" when it wants "http". This is true in all browsers I've tried (except Midori). And thus it prevents me from login in to the admin interfa...
- Apr 24, 2025
The workaround is to simply turn off https at the router. Login on a browser that allows it (I used Midori), go to Advanced -> Advanced Setup -> Web Services Management, uncheck "Always use HTTPS to access Router" and click "Apply". This is of course less secure, and Netgear really should "keep up", but...
Netduma-Fraser
Apr 22, 2025NetDuma Partner
It's because most web browsers now try to force HTTPS/secure connections. You may be able to disable this in the browser settings or look up online how to do so using the more advanced settings
tunkul
I've tried asking the AI how to disable the forcing of https in the browser, and everything it suggested fails (including explicit ip, incognito mode, ...). Was just wondering if somebody knew how to do this *correctly* in Chrome.
