tunkul
Apr 22, 2025Aspirant
unable to access router admin page due to https
Trying to hit routerlogin.net keeps switching over to "https" when it wants "http". This is true in all browsers I've tried (except Midori). And thus it prevents me from login in to the admin interfa...
- Apr 24, 2025
The workaround is to simply turn off https at the router. Login on a browser that allows it (I used Midori), go to Advanced -> Advanced Setup -> Web Services Management, uncheck "Always use HTTPS to access Router" and click "Apply". This is of course less secure, and Netgear really should "keep up", but...
tunkul
Apr 23, 2025Aspirant
Ok, turns out the problem is not http vs https, the router is listening on 443 fine (confirmed with telnet).
It's a cert issue. This is the error I get:
ERR_SSL_KEY_USAGE_INCOMPATIBLE
This happens on both Edge and Chrome, but Midori is fine, although it does say "warning". I did update the firmware, same error.
And it doesn't matter whether I use the IP or routerlogin.net. And note that this was NOT a problem 1 year ago (last time I accessed the admin interface).
I emailed support, we'll see.
tunkul
Apr 24, 2025Aspirant
- FURRYe38Apr 29, 2025Guru - Experienced User
I've found that HTTPs really isn't needed. Been using HTTP for years. Unless your not the only one accessing the WEB ui, you can't use HTTP all the time.
Enjoy.
