JPW162's avatar
JPW162
unable to access routerlogin.net on ethernet, works on WiFi
Hi,
I am unable to access routerlogin.net on ethernet, i can access the DumaOS page fine on my phone connected through wifi, I have previously been able to access routerlogin.net on my PC with ethernet.
I have been using chrome and tried clearing cache etc, I have also tried edge and firefox however when I try to access the page to login I am sent to this page: https://www.netgear.com/home/products/networking/routerlogincom.html
I have also tried rebooting the router.
Please could anyone assist?
  • FURRYe38's avatar
    Does 192.168.1.1 work?
    Make sure your PC is getting a IP address from the router correctly.
    Has the router changed from 192.168.1.1 to something else if you have a router in front of the XR router? It may do this in this configuration to avoid IP collison.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      As above can you access via the LAN IP? If so then you may have an adblock or anti-virus on that PC that may be blocking the routerlogin.net URL.
