Proxid
Jul 19, 2020Follower
Unable to connect to 192.168.1.1
The way I have my roughter set up is my main desktop is wired directly from router to lan. Everything else, TV, laptops, phones, gaming consoles are connected via Wi-Fi. In the Advance setting I ...
Netduma-Fraser
Jul 20, 2020NetDuma Partner
Sounds like you have a different router to the XR series so would recommend posting in the Nighthawk section: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
