Retired_Member
Nov 14, 2019Unable to connect to any external FTP servers
Hi I have a really weird issue where my brand new PC build will not connect to ANY external FTP sites using any FTP software Filezilla, Cuteftp, WinSCP etc other PC's on the same network can connect ...
Nov 14, 2019Guru - Experienced User
Netduma-Fraser
Nov 14, 2019NetDuma Partner
Could you try disabling QoS completely from the Anti-Bufferbloat menu please and see if that helps at all?
- Retired_MemberNov 14, 2019
Netduma-Fraser wrote:
Could you try disabling QoS completely from the Anti-Bufferbloat menu please and see if that helps at all?Hi thank you for taking the time to reply, however I have already disabled QoS and it made no difference whatsoever.
I am fully out of ideas how can one PC that is hardwired to the XR500 be able to connect and use all my external FTP servers just fine but another PC also hardwired to the XR500 have issues using any of them?
I have tried different, cables, network adapters, WiFi makes no difference but as soon as I remove the XR500 from the network and add any other router I have available I can connect and use all servers just fine.
I have even reset the XR500 to factory settings nothing helps.
Anything else I can try?
- Netduma-FraserNov 14, 2019NetDuma PartnerIn WAN settings could you toggle IGMP Proxying please? This very well could be the cause.
In WAN settings could you toggle IGMP Proxying please? This very well could be the cause.I had that turned off but I have now tried it both on and back off again and it has made no difference, running out of ideas now tbh, it's a shame because I really do like the router.
