Butterz_87's avatar
Butterz_87
Follower
Jan 16, 2021
Unable to connect to Call of Duty Modern Warfare Servers after route update
Hello
I noticed that there was an update avalible for my router. Which I applied yesterday since then I've not been able to connect to any game!
Before the update I had a geo filter enabled (whole reason of purchasing the router). I have removed this but still unable to connect. it also lost a number of other settings I had altered!
I've had issues similar to this in the past but appear to self resolve? Not happy considering how much the router cost!
Have others had a similar issue? is there a Common fix?
thanks!
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You may try to revert the firmware back or try a factory reset on the router and set it up again.
    DarrenM
  • I'd suggest going ahead and performing a factory reset, as you've lost settings anyway it would be best to start fresh as it could prevent the issues you're having.
