Compoza_
Mar 09, 2021Luminary
unable to delete a device from the Device Manager
I'm not able to delete the device, Samsung SmartTv, from Device Manager. I have resetted/disabled the wifi on the tv, but still it says it is online. Any ideas how to remove it from the list? her...
DotDashh
Nov 05, 2023Aspirant
any update on this? I also have a unknown device that i have blocked but can't delete, It just shows the delete button as greyed out. It's definitely not anything i use or need. I tried to search the mac address but couldn't find anything so I have no idea what this is.
Netduma-Fraser
Nov 05, 2023NetDuma Partner
If you reboot the router you should be able to delete it after that
