DylanK
Aug 10, 2022Tutor
Unable to Edit/Delete Traffic Controller rules
Is this fixed yet?
Netduma-Fraser
Aug 11, 2022NetDuma Partner
I don't think anyone has brought up this issue before, what happens exactly when you try to delete a rule?
- DylanKAug 11, 2022Tutor
After doing the factory reset from GUI (not using pushing the pin from physical router), the rules dont show up.
As you can see here, I can see that the rules are there from traffic analytics but under the rules nothing show up.
Log shows:
[DumaOS] RPC call 'get_device' exception 'ERROR: Nonexistent device stack traceback: ^I?: in function '__new__' ^I?: in functio,
[DumaOS] RPC call 'get_device' exception 'ERROR: Nonexistent device stack traceback: ^I?: in function '__new__' ^I?: in functio,- Netduma-FraserAug 11, 2022NetDuma PartnerWhen you do a factory reset it wipes settings as though you were setting it up from scratch so that is normal. The log entries don't necessarily refer to Traffic Controller specifically.
It is not normal. Even if I create a new rule, it doesn't show up. Nothing shows up under rules.
