DylanK
Aug 10, 2022Tutor
Unable to Edit/Delete Traffic Controller rules
Is this fixed yet?
Netduma-Fraser
Aug 11, 2022NetDuma Partner
I don't think anyone has brought up this issue before, what happens exactly when you try to delete a rule?
DylanK
Aug 11, 2022Tutor
After doing the factory reset from GUI (not using pushing the pin from physical router), the rules dont show up.
As you can see here, I can see that the rules are there from traffic analytics but under the rules nothing show up.
Log shows:
[DumaOS] RPC call 'get_device' exception 'ERROR: Nonexistent device stack traceback: ^I?: in function '__new__' ^I?: in functio,
- Netduma-FraserAug 11, 2022NetDuma PartnerWhen you do a factory reset it wipes settings as though you were setting it up from scratch so that is normal. The log entries don't necessarily refer to Traffic Controller specifically.
