DylanK
Aug 10, 2022Tutor
Unable to Edit/Delete Traffic Controller rules
Is this fixed yet?
DylanK
Aug 11, 2022Tutor
After doing the factory reset from GUI (not using pushing the pin from physical router), the rules dont show up.
As you can see here, I can see that the rules are there from traffic analytics but under the rules nothing show up.
Log shows:
[DumaOS] RPC call 'get_device' exception 'ERROR: Nonexistent device stack traceback: ^I?: in function '__new__' ^I?: in functio,
Netduma-Fraser
Aug 11, 2022NetDuma Partner
When you do a factory reset it wipes settings as though you were setting it up from scratch so that is normal. The log entries don't necessarily refer to Traffic Controller specifically.
- DylanKAug 11, 2022Tutor
It is not normal. Even if I create a new rule, it doesn't show up. Nothing shows up under rules.
Will this go away if I use the reset button to factory reset instead of doing it from GUI?
- Netduma-FraserAug 11, 2022NetDuma PartnerIf it's not resetting correctly via the interface then a reset through the hardware should complete successfully, let us know
