DylanK
Aug 10, 2022Tutor
Unable to Edit/Delete Traffic Controller rules
Is this fixed yet?
DylanK
Aug 11, 2022Tutor
2.3.2.134
The browser I used are chrome and firefox and both shows same problem.
Netduma-Fraser
Aug 11, 2022NetDuma Partner
Did the physical factory reset wipe it properly this time?
- DylanKAug 11, 2022Tutor
Not yet. I will try that in a few hours as I need wifi now.
- DylanKAug 12, 2022Tutor
Nope. Still doesnt work after hard reset.
- Netduma-FraserAug 14, 2022NetDuma PartnerWhen did this issue start exactly? What options did you pick for the rules? Are there any rules you did with different options that have been wiped after resets?
