ebenasky
Jan 16, 2020Aspirant
Unable to find setting up Remote Management after firmware update
I searched for an answer to this - but I wasn't able to find one. When I first got my Nighthawk XR300, I was able to go into settings>advanced settings and set up remote management. Since I have...
ebenasky
Jan 22, 2020Aspirant
When I first purchased this router, I have the ability to make setting to the remote management. After a firmware update, I am no longer finding that setting in advanced or anywhere else I look. I am trying to connect to the router with a PC that is on the same LAN as the router - so no DMZ is in place. I tried to roll back to previous versions of firmware just in case I might be able to find the setting and I had no luck so I re-installed the newest version.
I tried https to the IP address of the router with ports 8080 and 8443 with no luck. I turned on the ability to ping the router and it does return a ping.
At this point, I am giving up on doing remote access and I will connect directly to the LAN port if I need to do maintenance.
I have loaded the App on my phone so I can do some simple things like a reboot if needed.
Netduma-Fraser
Jan 22, 2020NetDuma Partner
I'm not sure I understand, if the device is on your LAN what is the purpose of connecting via the WAN address instead of the LAN address?
- ebenaskyJan 24, 2020Aspirant
My apologies for writing down the wrong thing.
The laptop that I am now going to use to do maintenance will be plugged directly into one of the LAN ports off of the Nighthawk. The computer that I was trying to use to access the remote management is on the same WAN as the router with out a DMZ. It is this computer that I was not able to do any remote management.
I do not know what changed in my firmware of the XR300 - but since it is working OK except for the remote management, I am not going to worry about it and just do a work around with a direct connect in case I need to make changes. Next time I will just get a different router.
Thanks
- Netduma-FraserJan 25, 2020NetDuma PartnerI will enquire with Netgear to see if there has been any changes to RM on the XR300, sorry for the inconvinience.
- Spas_MoToJan 29, 2020Aspirant
I have the exact same problem with my XR300. I can only connect remotely to it via the Nighthawk app on Android, but I can not connect remotely via a laptop browser running Windows. And the remote access setting in the router software is not available any more after updating to the latest firmware. Please, advise how can I connect remotely to the router, so I can manage it. I tried via the ip of the router http://xxx.xxx.x.xx:8080, but I can not connect to it.
