usermac
Aug 03, 2018Luminary
Unable to install because some filters are overlapping.
When you add a device the geo filter ask for the game. What I dont under stand is if I add the same device one that is set up for PUBG and then try to add the same device to work with Call Of Duty fo...
Netduma_Jack
Aug 04, 2018NetDuma Partner
Good catch. The CoD profile uses most UDP ports, so it's rule overlaps with PUBG when you add that too. So I recommend you just use the CoD profile for both games. It will have no impact on your experience - you will be able to see all the PUBG servers etc and block accordingly.
Could you try this please.
usermac
Aug 04, 2018Luminary
I have done what you said but something does not seem right I am also getting really high ping host I will post screen shot.
