Xrv
Sep 30, 2020Guide
Unable to install Plex V1.0.1.34
I am not able to install Plex server after updating to the latest firmware V1.0.1.34. I did a factory reset after installing the firmware and I try two different USB drives without any success.
Netduma-Fraser
Oct 02, 2020NetDuma Partner
The timezone may be inaccurate on the router, update the timezone to your region and then try to update plex again.
Xrv
Oct 02, 2020Guide
I already double checkt and the time zone it's correct. I had similar problem before when I used the DNS addres from vpn provider but that was with a previous firmware. Any new suggestions?
- Netduma-FraserOct 02, 2020NetDuma PartnerSo you're not doing that again this time? How is the XR connected to your setup is it behind a modem or a modem/router?
- XrvOct 02, 2020GuideIt's correct, I am not doing that.
The router is direct connected to the internet, it's not behind modem.- Netduma-FraserOct 02, 2020NetDuma PartnerI think creating a ticket would be best for this issue as it is a Netgear feature: http://support.netgear.com/
