JavelinSST71
Mar 04, 2026Guide
Unable to view/access XR1000 USB Storage in Windows Pro 11 File Explorer
Setting up a new Windows Pro 11 laptop. I want to use Windows File Explorer to view and access all folders/files within my WD External HD (connected to XR1000 through USB). Environment Details: ...
- Mar 17, 2026
I'm back working on this issue! It appears, from all I've read, that it is a problem with a Microsoft update. I was able to finally follow the link provided by StephenB - and successfully mapped my WD hdd 1021 (through USB port on XR1000) and have access to all folders/files! Here are the steps I followed:
- Ran Powershell as administrator
Get-SMBClientConfiguration (to verify EnableInsecureGuestLogons was set as False and RequireSecuritySignature was set as True)
Ran the following
Set-SMBClientConfiguration -EnableInsecureGuestLogons $true
Set-SMBClientConfiguration -RequireSecuritySignature $false
- Restarted computer
- Opened File Explorer and mapped to \\readyshare\USB_Storage
Thanks to everyone for your help and support!
JavelinSST71
Mar 04, 2026Guide
Thank you. I didn't use readyshare as the user name, I will give that a try.
Unfortunately that didn't work - still couldn't get past the Enter network credential page.
Mar 04, 2026Guru - Experienced User
JavelinSST71 wrote:Thank you. I didn't use readyshare as the user name, I will give that a try.
One option is here:
- JavelinSST71Mar 04, 2026Guide
Thank you again. It seems like the same error message I'm receiving. I'm a 'little' comfortable with PowerShell but not to modify settings I don't quite understand. What risk am I taking by running the commands to re-enable guest access to Samba drives?
- FURRYe38Mar 04, 2026Guru - Experienced User
Acutally, If you have Win11, try enabling SMB v1.0 on the control panel/programs and features/turn On or OFF Windows freatures. Looks for SMB Client v1.0. Apply and reboot the PC.
We must have submitted this thought at the same time! I've just enabled that on Windows Feature and rebooted. Tried again and still not able to access \\readyshare. I'm not sure what I'm missing here as I didn't have anywhere this issue with my previous Win Home 11 laptop. Thank you.
Would the same re-enable guest access be accomplished by going through Windows Features and checking the SMB 1.0/CIFS... option?
- StephenBMar 04, 2026Guru - Experienced User
No. But I think would also need the SMB 1.0/CIFS client enabled anyway. If you haven't done that, then try that next.
The general risk is that the change isn't selective - it allows the PC to access any shared folder w/o authentication. That does create the possibility of a man-in-the-attack (where a bad actor could get "in the middle" of the data flow). Such an actor could do a ransomware attack. The odds of this happening on your home network are pretty low (and such an actor would be able to access the files on the drive directly). But potentially higher if you access shared folders when connected to other networks.
Another path you could take is to not use Samba, and instead use FTP to access the drive. FileZilla and WinSCP are two free clients you can use. These both have useful GUIs - not the same as Windows Explorer, but still intuitive and functional.
- JavelinSST71Mar 17, 2026Guide
Ran the following
- FURRYe38Mar 17, 2026Guru - Experienced User
Good to know.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
