edddennis
Mar 13, 2022Aspirant
Unable to watch BT HD TV error IPC 6023 using Netgear XR500
Hello all, I have recently purchase the XR500 and immediately I am encountering numerous errors which are very frustrating - was not expecting to have such issues and needing to have done mountai...
- Mar 13, 2022Glad to hear that is working. The Nest may only be able to connect to 2.4GHz so disable Smart Connect in WiFi settings and connect it manually to 2.4GHz and see if that works. Port forwarding shouldn't be necessary as UPnP is enabled by default. Speeds could be due to your QoS settings but check the Device Manager table view (click the 3 line horizontal icon) and see what the link speeds are for the ports, if they're restricted to 100Mbps you'll need to try different ethernet cables to get better speeds.
Mar 13, 2022Guru - Experienced User
not sure with the pro-gamer xr500 but have you tried enabling the IPTV options?
There's different vlan options depending on your isp, for example:
Configuring VLAN IPTV setup on your Nighthawk router | Answer | NETGEAR Support
Might be worth checking on your isp's site/forum for the proper setup for vlan and your isp.
edddennis
Hi thanks - i have sorted it for now. I have disabled "Disable IGMP Proxying" and ticked enable BT Proxying which seems to have done the trick. Hopefully can my issues resolved 1 by 1 as i want the router optimized to it's best capability.
