joebp22703
Aug 16, 2019Aspirant
Unauthorised xr500
I tried to login on the router via routerlogin.net and without giving me any time to type my password it automatically loads this screen. Can you please help me fix this?
joebp22703
Aug 17, 2019Aspirant
It says I have an ad blocker, but I don’t even have one installed. Don’t really understand.
Aug 17, 2019Guru - Experienced User
What browswer are you using? Try IE11, FireFox or Opera browsers...
- joebp22703Aug 18, 2019AspirantI’m using Chrome Beta (64 bit). I am also using Kaspersky Anti Virus. Could that be interfering with the page having these errors?
- FURRYe38Aug 18, 2019Guru - Experienced User
Temporarily disable Kaspersky and see.
Does other browsers work?
- Netduma-FraserAug 20, 2019NetDuma PartnerAny update on this issue joe?
