Zevas1993
Apr 27, 2022Tutor
Uncaught TypeError: $(...)[0].getApp is not a function
i just updated the firmware and now i get this code
- Dec 05, 2022
Nevermind Clearing cashed images and files the pasted hour fixed it
michaelkenward
Apr 28, 2022Guru - Experienced User
Updated the firmware on what Netgear device? And from what firmware version to what version?
And where do you see the message buried in your subject?
Zevas1993
Apr 28, 2022Tutor
What to do if message is displayed after update, please give a solution
- FarinesApr 29, 2022Aspirant
reset toujours message error
- Netduma-FraserApr 29, 2022NetDuma PartnerFarines if you're having an issue please make a new topic explaining the problem and we'll be happy to help.
- michaelkenwardApr 29, 2022Guru - Experienced User
You will have to explain that.
What are you doing?
What happens?
What error messages? And when?
- PaulthePirateApr 29, 2022Aspirant
I'm having the same issue XR1000 gaming router, I updated from .58 to .64 or whatever the newest version is.
Btw, factory resetting a router every time you update the firmware is completely ridiculous and unacceptable. That's the equivalent of asking a Windows 10 user to reset their PC every month after patch Tuesday. Was a huge mistake to buy this router in the first place, it's complete garbage. In the 18 months that I've owned it, this will be the 4th or 5th time I've had to factory reset it.
To make matters worse, the "backup" feature is completely broken. No matter what changes you make, and when you restore from a backup, it is still the default settings. Again, this thing is complete garbage, shame on you Netgear.
