Zevas1993
Apr 27, 2022Tutor
Uncaught TypeError: $(...)[0].getApp is not a function
i just updated the firmware and now i get this code
- Dec 05, 2022
Nevermind Clearing cashed images and files the pasted hour fixed it
Zevas1993
Apr 28, 2022Tutor
I believe I was on 5084 and I updated to the most recent on the xr1000. I've been having issues for over a year now and I thought updating would help, now DumaOS doesn't even load and after 5 minutes of a red screen with a spinning white circle that error message pops up.
michaelkenward
Apr 28, 2022Guru - Experienced User
That's not a Netgear firmware number. Maybe it is a Duma thing.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message.
That's why it always helps to provide as much detail as possible when seeking help.
- Zevas1993Apr 28, 2022TutorI was on the 1.0.0.58 and updated to the 1.0.0.64
https://www.netgear.com/support/product/xr1000.aspx#Firmware%20Version%201.0.0.64- Netduma-FraserApr 28, 2022NetDuma PartnerDid you factory reset after upgrading as that is recommended and should clear the error
- Zevas1993Apr 28, 2022TutorNo I did not I will have to try that after work. I'll only be able to do that with the button on the router because that error causes me to be unable to login to the router but the internet still works
