Zevas1993
Apr 27, 2022Tutor
Uncaught TypeError: $(...)[0].getApp is not a function
i just updated the firmware and now i get this code
- Dec 05, 2022
Nevermind Clearing cashed images and files the pasted hour fixed it
Zevas1993
Apr 28, 2022Tutor
192.168.0.1 takes me to the modem 10.0.0.1 takes me to Duma
Netduma-Fraser
Apr 28, 2022NetDuma Partner
So 10.0.0.1/adv_index.htm will take you to the settings
- Zevas1993Apr 28, 2022TutorOkay where do I go to do a factory reset? I'm not seeing that option.
- michaelkenwardApr 29, 2022Guru - Experienced User
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Return the Router to its Factory Default
Settings. Or press the "button" on the back. - Netduma-FraserApr 29, 2022NetDuma Partner10.0.0.1/adv_index.htm will take you to the settings so that you can factory reset
