Zevas1993
Apr 27, 2022Tutor
Uncaught TypeError: $(...)[0].getApp is not a function
i just updated the firmware and now i get this code
- Dec 05, 2022
Nevermind Clearing cashed images and files the pasted hour fixed it
Netduma-Fraser
Jun 14, 2022NetDuma Partner
Did you clear your browser cache/cookies as above?
Wayned20
Jun 14, 2022Aspirant
I just redownloaded the firmware I was on before the update cause clearly the firmware update was the problem and no I didn't I don't really plan on update to that firmware and try 50 million thing for it to work when I was fine on the past firmware
- Netduma-FraserJun 14, 2022NetDuma PartnerThat's certainly up to you, it worked for the previous user so it's a good thing to try if you decide to reupgrade
- GabeThaVikingDec 05, 2022Tutor
hey i am now having this same issue when trying to get into DUMAOS 3.0 and i even tried factory resetting. is there a fix for this yet?
