PieCaptain
Nov 16, 2019Guide
Uncaught TypeError: Cannot read property 'type' of undefined
I've started getting an error when trying to load hybrid VPN settings "Uncaught TypeError: Cannot read property 'type' of undefined" The result is that the client list doesn't load I've foun...
PieCaptain
Nov 17, 2019Guide
"did you have a device added there previously with a specific name/device type and then upgraded the router and the name changed or something along those lines?"
yes, i deleted it from device manager
Netduma-Fraser
Nov 17, 2019NetDuma Partner
Just a note to remember for the future it's not a good idea to restore using a backup from a previous firmware as they may work differently. It's best when doing a reset to just set up from scratch and then make a back up so if you reset on that same firmware then you can restore. Yes the deletion likely caused it.
- PieCaptainNov 18, 2019Guide
i know, it just takes ages haha
Is it possible to raise a feature request to that device manager is a bit more integrated?
E.G. deleting an device also removes it from anywhere else it might be
and renaming a device renames it everywere (e.g. in LAN setup/DHCP settings)
oh, and doing DHCP reservations from device manager too?- Netduma_AlexNov 18, 2019NetDuma Partner
In the future we'd like to have these features integrated more neatly between the Netgear firmware and DumaOS.
