Rick6922
Jun 28, 2019Luminary
under QOS should I have my console added or just dumos classified checked?
should I add the the xbox1x and in the advanced then add port number being used? I read on a post in these fourms not to have both checked[ classified games ,console] because it could cause double pr...
Rick6922
yeah, I only play one game and its port is 3074, there shouldnt be a lot of down loads from the xbox, I dont use it for anything accept that game. no youtube nothing.
Netduma-Fraser
Jun 29, 2019NetDuma Partner
Either DumaOS Classified Games enabled or adding it with the console service manually is fine, wouldn't suggest doing both as either will work fine on their own.
