JoeFI
Sep 30, 2020Apprentice
Uninvited device
Hi, there is a an xbox connected to my network, I don't own one. I have changed the password and it's still connected and when I try to delete it says it's online so I cannot. Can anyone help please?...
Sep 30, 2020Guru - Experienced User
Are you seeing it through the browser? or the app?
You cahnged the wireless password?
how about changing the ssid?
I'd start with changing the ssid and then when connecting devices back to the wireless, check to see what each is called. maybe the system is mis-identifying a device.
JoeFI
Oct 01, 2020Apprentice
It was the browser. I managed to delete it eventually. I've removed my devices that had doubled up as wireless and wired where I was testing connection differences. I'll keep an eye out for it reconnecting. But thanks for your help
Regards Joe
Regards Joe
- plemansOct 01, 2020Guru - Experienced User
glad to see you got it figured out!
