Manuellll
Oct 01, 2019Apprentice
Unknown error
someone knows that this error gives me my xr500? Uncaught TypeError: Cannot read property 'removeChild' of null
Netduma-Fraser
Oct 01, 2019NetDuma Partner
It is likely nothing to be concerned with. How often does it appear? Does it go away after saying okay?
Manuellll
it is done every time I log into the router gives me that message, another question I broke the cable provided with the netgear cat5e FTP router if I replace it with a cat5e UTP is it a problem could interefernere the router with the modem?
- FURRYe38Oct 01, 2019Guru - Experienced User
What browser are you using?
Does this happen after a factory reset?
What FW version is loaded on the router?
- Netduma-FraserOct 01, 2019NetDuma PartnerIs it on any particular page of the router? When did it start to occur?
FTP cables can remove interference but it should be fine to use a UTP cable.- ManuellllOct 02, 2019Apprentice
I use google crhome, I did the factory reset, FW the V2.3.2.56, the screen appears on the main page of the router as soon as I open it
- Netduma_AlexOct 02, 2019NetDuma Partner
Does the page appear on every device that you connect from? Have you tried any different browsers?
