Manuellll
Oct 01, 2019Apprentice
Unknown error
someone knows that this error gives me my xr500? Uncaught TypeError: Cannot read property 'removeChild' of null
Manuellll
it is done every time I log into the router gives me that message, another question I broke the cable provided with the netgear cat5e FTP router if I replace it with a cat5e UTP is it a problem could interefernere the router with the modem?
Oct 01, 2019Guru - Experienced User
What browser are you using?
Does this happen after a factory reset?
What FW version is loaded on the router?
