Manuellll
Oct 01, 2019Apprentice
Unknown error
someone knows that this error gives me my xr500? Uncaught TypeError: Cannot read property 'removeChild' of null
Netduma_Alex
Oct 02, 2019NetDuma Partner
Does the page appear on every device that you connect from? Have you tried any different browsers?
Manuellll
Oct 02, 2019Apprentice
you give it to me on the router page
- ManuellllOct 02, 2019Apprentice
with internet explorer it seems that it doesn't give me errors with google crhome could it be adblock? but I removed it from the router site, I don't understand
- FURRYe38Oct 02, 2019Guru - Experienced User
Disable any ad block in Chrome, empty caches. close Chrome then relaunch and test.
If this is seen still in Chrome, then this would probably be a Chrome issue. Seen issues with recent Chrome versions.
I haven't had any problems with Opera or FF.
- Netduma-FraserOct 02, 2019NetDuma PartnerEasiest way to tell would be to access the interface using an Incognito Chrome window and see if the error still occurs.
yes in icognito persists
