Manuellll
Oct 01, 2019Apprentice
Unknown error
someone knows that this error gives me my xr500? Uncaught TypeError: Cannot read property 'removeChild' of null
Netduma-Fraser
Oct 02, 2019NetDuma Partner
Would agree with the above, there is another known issue on Chrome we're aware of so may be related to that version.
Manuellll
Oct 09, 2019Apprentice
so nothing to worry about? an off-topic question about the xr500 but if I have to open the same ports in the protocol (TCP and UDP) if I open TCP and after UDP or open them with the TCP / UDP protocol there is a difference? I always prefer to open the tcp first and then the udp even if they are the same ports and could I make TCP / UDP wrong?
- Netduma_AlexOct 09, 2019NetDuma Partner
There's no reason to do them seperately if you're going to open both anyway... But I guess if you wanted to do that, it would work.
- ManuellllOct 09, 2019Apprentice
so you're telling me that there would be no problem opening them separately, but if I open both protocols directly in a rule, is it better?
- Netduma-FraserOct 09, 2019NetDuma PartnerJust quicker to open using TCP/UDP but still fine to do it the long way and do TCP then UDP if you want to.
- ManuellllOct 28, 2019Apprentice
are there port forward to open for the xr500? or to speed up the internet in general, since it downloads very slowly you could help me?
- Netduma_AlexOct 29, 2019NetDuma Partner
Port forwarding is for specific devices on your network.
The only time you'd need to forward ports for the XR500 itself is if it was connected to another router upstream.
If that's the case, you should instead be putting the XR500 into the DMZ of the router above so that everything is forwarded to the XR500.
Even better would be bridge mode.
- ManuellllOct 29, 2019Apprentice
I have a vodafone station where I connected the xr500 in cascade and on the vodafone station I put the xr500 ip wan in the static nat section, should I insert the xr500 ip wan also in the dmz section of the vodafone station? how can I put it in bridge mode?
Yes I think you should put the XR500's IP into the DMZ of the Vodafone Station.
perfect, instead the static nat that they advised me to put if I connected a router in cascade to the vodafone station can you explain to me what is it for?
- Netduma-FraserOct 29, 2019NetDuma PartnerCascade just mean two routers connected to eachother. So by putting it in this mode will mean the two work better together.
- ManuellllOct 31, 2019Apprentice
so i dont need it open port on router if I put the ip wan of the router in the dmz section of the vodafone station?
- Netduma-FraserOct 31, 2019NetDuma PartnerPut the XR in the DMZ then you can leave the settings alone on the Vodafone. You should be able to then get an Open NAT on the device connected to the XR using UPnP.
ok, but I have to remove the reservation of my computer's ip address to activate the upnp right?
- Netduma-FraserOct 31, 2019NetDuma PartnerNo you don't they're separate, UPnP is intelligent port forwarding as and when needed essentially. It will know to open ports for the device.
I speak of the reservation of the ip address on the XR must be removed for upnp since usually you book an ip address if necessary to open the port
- Netduma-FraserOct 31, 2019NetDuma PartnerNo you don't need to do that. Static IPs are not just done for port forwarding. They are useful to keep the router from giving it new IP addresses.
ok so I remove portforwarding and put upup?
- Netduma-FraserOct 31, 2019NetDuma PartnerIf you have an Open NAT then leave your settings as they are, if you don't then yes try that or put the console in the XR DMZ.
I do not have a console but a gaming gaming PC and it is a bit risky to put it in dmz, what I wonder if the upnp automatically manages the ports to open what is the purpose of booking an ip address?
- FURRYe38Oct 31, 2019Guru - Experienced User
uPnP is all thats needed for gaming for a single game console or game PC online at one time. Shouldn't need any PF configurations. DMZ is not recommended for your PC.
- ManuellllNov 01, 2019Apprentice
yes, but I have not yet figured out what it takes to reserve the ip address with the active update
- Netduma-FraserNov 02, 2019NetDuma PartnerI'm not sure I understand, you said you have already reserved the IP correct? You don't need to do anything further.
- ManuellllNov 02, 2019Apprentice
I mean that before activating upnp I had the portforward and I had booked the ip address of the pc in the lan section now that I put the upnp I have to remove the reservation of the ip address or leave it?
- Netduma-FraserNov 03, 2019NetDuma PartnerYou can leave the IP reservation.
- ManuellllNov 20, 2019Apprentice
did I do well to put the static router ip on both the modem and the router itself?
- Netduma-FraserNov 20, 2019NetDuma PartnerYes thats absolutely fine.
