Manuellll
Oct 01, 2019Apprentice
Unknown error
someone knows that this error gives me my xr500? Uncaught TypeError: Cannot read property 'removeChild' of null
Netduma_Alex
Oct 29, 2019NetDuma Partner
Port forwarding is for specific devices on your network.
The only time you'd need to forward ports for the XR500 itself is if it was connected to another router upstream.
If that's the case, you should instead be putting the XR500 into the DMZ of the router above so that everything is forwarded to the XR500.
Even better would be bridge mode.
Manuellll
Oct 29, 2019Apprentice
I have a vodafone station where I connected the xr500 in cascade and on the vodafone station I put the xr500 ip wan in the static nat section, should I insert the xr500 ip wan also in the dmz section of the vodafone station? how can I put it in bridge mode?
- Netduma_AlexOct 29, 2019NetDuma Partner
Yes I think you should put the XR500's IP into the DMZ of the Vodafone Station.
- ManuellllOct 29, 2019Apprentice
perfect, instead the static nat that they advised me to put if I connected a router in cascade to the vodafone station can you explain to me what is it for?
- Netduma-FraserOct 29, 2019NetDuma PartnerCascade just mean two routers connected to eachother. So by putting it in this mode will mean the two work better together.
- ManuellllOct 31, 2019Apprentice
so i dont need it open port on router if I put the ip wan of the router in the dmz section of the vodafone station?
- Netduma-FraserOct 31, 2019NetDuma PartnerPut the XR in the DMZ then you can leave the settings alone on the Vodafone. You should be able to then get an Open NAT on the device connected to the XR using UPnP.
ok, but I have to remove the reservation of my computer's ip address to activate the upnp right?
- Netduma-FraserOct 31, 2019NetDuma PartnerNo you don't they're separate, UPnP is intelligent port forwarding as and when needed essentially. It will know to open ports for the device.
I speak of the reservation of the ip address on the XR must be removed for upnp since usually you book an ip address if necessary to open the port
- Netduma-FraserOct 31, 2019NetDuma PartnerNo you don't need to do that. Static IPs are not just done for port forwarding. They are useful to keep the router from giving it new IP addresses.
ok so I remove portforwarding and put upup?
- Netduma-FraserOct 31, 2019NetDuma PartnerIf you have an Open NAT then leave your settings as they are, if you don't then yes try that or put the console in the XR DMZ.
I do not have a console but a gaming gaming PC and it is a bit risky to put it in dmz, what I wonder if the upnp automatically manages the ports to open what is the purpose of booking an ip address?
- FURRYe38Oct 31, 2019Guru - Experienced User
uPnP is all thats needed for gaming for a single game console or game PC online at one time. Shouldn't need any PF configurations. DMZ is not recommended for your PC.
- ManuellllNov 01, 2019Apprentice
yes, but I have not yet figured out what it takes to reserve the ip address with the active update
- Netduma-FraserNov 02, 2019NetDuma PartnerI'm not sure I understand, you said you have already reserved the IP correct? You don't need to do anything further.
- ManuellllNov 02, 2019Apprentice
I mean that before activating upnp I had the portforward and I had booked the ip address of the pc in the lan section now that I put the upnp I have to remove the reservation of the ip address or leave it?
- Netduma-FraserNov 03, 2019NetDuma PartnerYou can leave the IP reservation.
- ManuellllNov 20, 2019Apprentice
did I do well to put the static router ip on both the modem and the router itself?
- Netduma-FraserNov 20, 2019NetDuma PartnerYes thats absolutely fine.
perfect I was wondering why even in the modem where the router is connected in cascade I put the ip from the router from the modem, in the static static of the modem and I wouldn't want it then to cause problems
- Netduma-FraserNov 20, 2019NetDuma PartnerI'm not really sure I understand the question, could you clarify?
the modem where the xr500 is connected is an option, it's called static nat, where I entered the ip wan of the router, so I wouldn't want it to give problems with that option, also insert the static ip on the ipv4 section of the modem
- Netduma-FraserNov 20, 2019NetDuma PartnerDo you have it in the DMZ as well? Usually it's better to refrain from changing too many options if you're not sure what they do.
yes i have in dmz
- ManuellllDec 02, 2019Apprentice
why if I put my pc as xbox it prioritizes me fortnite otherwise not? doing so does it not prioritize wrong packages being different PCs and consoles?
