Manuellll
Oct 01, 2019Apprentice
Unknown error
someone knows that this error gives me my xr500? Uncaught TypeError: Cannot read property 'removeChild' of null
Netduma-Fraser
Nov 20, 2019NetDuma Partner
I'm not really sure I understand the question, could you clarify?
Manuellll
Nov 20, 2019Apprentice
the modem where the xr500 is connected is an option, it's called static nat, where I entered the ip wan of the router, so I wouldn't want it to give problems with that option, also insert the static ip on the ipv4 section of the modem
- Netduma-FraserNov 20, 2019NetDuma PartnerDo you have it in the DMZ as well? Usually it's better to refrain from changing too many options if you're not sure what they do.
- ManuellllNov 20, 2019Apprentice
yes i have in dmz
