ron_spruce
Jan 31, 2023Star
Unmatched Device in Geo-Filter
I used to be able to see my PlayStation 5 as an added device in the Geo-Filter Map, now I do not. When I click on the Add Device button, nothing happens. Navigating away and back to the Geo-Filter wi...
- Feb 01, 2023
OK great thanks, let us know if you experience any further issues following a factory reset.
Netduma-Liam
Feb 01, 2023NetDuma Partner
Did this happen after a firmware update by chance? If so, I believe can you let me know which firmware version you upgraded from and to?
We'll try and reproduce this issue internally and resolve it, we've seen a similar one recently related to devices in QoS. The solution is unfortunately to factory reset the XR.
- ron_spruceFeb 01, 2023Star
I upgraded from V1.0.0.58_1.0.44 to V1.0.0.64_1.0.49
- Netduma-LiamFeb 01, 2023NetDuma Partner
Don't know if it helps but these logs appeared as I was seeing that popup in the Geo-Filter:
Feb 1 07:56:25 XR1000 user.info com.netdumasoftware.pingheatmap: Ping Heatmap looking for updates... 107 Feb 1 15:56:26 XR1000 user.info com.netdumasoftware.pingheatmap: Downloading files at mirror: http://netdumasoftware.com/dumaos/cloud_resources/ping-heatmap/GPG/3_0_0/cloud-0000000113-gpg.asc 198 Feb 1 15:56:27 XR1000 user.info com.netdumasoftware.pingheatmap: Cloudsync Ping Heatmap result 'true','Cloud is up to date' 130 Feb 1 07:56:55 XR1000 user.warn lua: config write 'com.netdumsoftware.geofilter.settings' 96 Feb 1 07:57:20 XR1000 user.info com.netdumasoftware.neighwatch: DHCP new event. 86 Feb 1 07:57:20 XR1000 user.info com.netdumasoftware.neighwatch: DHCP lease change. 89
