DMC51450
Apr 10, 2019Star
UNSTABLE TICKRATE and lan problems
What's up !!! After months testing the XR500 i found an insane problem... auto ping shows you the tick rate of the lobby and yours... well... my XR500 is NOT ABLE to keep a stable tick rate of 150 ...
Netduma_Jack
Apr 11, 2019NetDuma Partner
Hi DMC,
Which tickrate are you referring to specifically? Host tickrate or Client tickrate?
And which games are you measuring this on? Just BO4?
Please could you keep your response short, as it's quite overwelming to read through that much text!
DMC51450
Apr 11, 2019Star
BO4 ... WW2... BO3... Both host and client as i've mention !!! I uploaded public pics here in my account... from today's tests !!! Take a look !!!
- Netduma_JackApr 12, 2019NetDuma Partner
I don't think the pics posted, could you share them again please?
- DMC51450Apr 12, 2019StarOhhhh boy that's another shame...!!! I am not the dumb guy who made this site so it's not my fault if we can't upload pics directly on our posts like we can on netduma's forum ... But still there is 37 pics on my account here...in a public folder... so since you seems to not know how to see them i'll explain to you ...click on my name so it will bring you in my account...scroll down a bit and voilà you see the pics !!! At least since you working with netgear you should already knows that...or at least you could ask them so you don't look like you a noob !!!
- FURRYe38Apr 12, 2019Guru - Experienced User
Select this link for the users profile:
https://community.netgear.com/t5/user/viewprofilepage/user-id/709287
Then select Veiw ALL, left side, to see the pictures the user has uploaded to his profile...
- Netduma_JackApr 15, 2019NetDuma Partner
Thanks, had a look through the images.
Honestly, not sure if there's anything to be worried about there. Send and receive rates fluctuate depending on what's happening within the game. For example, if you're near a lot of other players and a lot of action is happening, it will spike.
If you're having an inconsistent experience, I don't think it's because of this.
Are you finding the pings consistent across each game?
