DMC51450
Apr 10, 2019Star
UNSTABLE TICKRATE and lan problems
What's up !!! After months testing the XR500 i found an insane problem... auto ping shows you the tick rate of the lobby and yours... well... my XR500 is NOT ABLE to keep a stable tick rate of 150 ...
DMC51450
Apr 18, 2019Star
I forgot to mention the lan problem which i think is related...
Premium Samsung 4k tv's are wrongly detected by duma os...with wrong name and type of device...but that's not even the problem...problem is the light is red on XR500 meaning tv is in sleep mode...even while the tv is open and on internet !!! Have to disable qos to enjoy internet browsing on our smart tvs !!! No need of disabling the qos if you on a computer since everything is flawless...but not on tvs !!! It is on our tvs when we change router like with the ROG GT AC5300...everything is properly detected and browsing is flawless... same with isp's aio's... but not with XR500 and R1 !!!
I already talked about that but then again you dismissed it...anyways still i can give more details once again !!!
And of course yes it do that on both XR500 that i have under the hands right now and also on R1 !!!
Samsung models are UN55MU8000 and UN55NU8000 !!!
Also i disabled the stay awake option on both tvs even if no need to do so with other routers !!!
Netduma-Fraser
Apr 21, 2019NetDuma Partner
Difference between R1 and XR500 is that you could be connecting to different servers. They have lots in the same location, if the ID is not exactly the same then it is a different server. If your settings are perfectly mirrored on both routers then there is nothing the router is doing to cause this. As I mentioned as well the game is perfectly capable at running that kbps rate. If lower their send rate and receive rate momentarily then there is nothing the router can do.
Not sure why you would need to disable QoS just when using the TVs, what are your QoS settings? When you turn the TVs off are they in a standby mode?
