Raf1212
Feb 18, 2021Apprentice
update 114
hello and immediately I have a question if someone checks the software before release, these are some jokes this software is as leaky as Swiss cheese, - upnp table not working - the qos website has...
Netduma-Fraser
Feb 18, 2021NetDuma Partner
Which firmware version are you referring to, the non beta or beta firmware? Could you also be more specific on QoS is not working properly etc please?
- Raf1212Feb 19, 2021Apprentice
Netduma-Fraser 114 from netgear, not a beta version, because beta 114 also, it does not work, you want more precisely it does not work, does not allocate the internet properly, I have a 49mb connection nothing is used but I want to download something to the phone and the phone takes 5mb and nothing more, and it is so also with other devices and it does not change the fact that the sliders are set to 70, moreover, I have already ordered from the USA a new asus GT-AXE11000, because I am about to switch to the 2 Gib fiber and what I know is no netgear and r2 do not support such speeds
- Netduma-LiamFeb 19, 2021NetDuma Partner
Thank you for the information.
What does a speedtest through your phone show? and if you then go and completely disabled QoS, do the speeds return to normal? If so, this would indicate that QoS is properly limiting bandwidth as we would expect.
