Alica11WTD
Oct 03, 2019Aspirant
Updating Firmware R7800, how?
So i've found there is a hotfix firmware update, and i cant uptade via phone app cuz it dosn't even show it there. Can i do it on my pc?
- Oct 03, 2019
Th R7800s IP addresss should be 192.168.1.1 if your using it's default IP configuration.
Oct 03, 2019Guru - Experienced User
Use your Pc and a wired connection to the router. Download the FW file and apply it thru the routers web page. I recommend using FireFox or Opera to do this.
- Alica11WTDOct 03, 2019Aspirant
So i've downloaded the firmware form netgear site its called R7800-V1.0.2.63_beta and its a img file
So i just connect to the router with wire and whats the router web page, do you meant the http://192.168.100.1 one!?
Thanks
- FURRYe38Oct 03, 2019Guru - Experienced User
i cant seem to find any update setting anywhere ....
L.E i've found it thanks for your help
