Jerome_w
Aug 18, 2021Tutor
Updating Firmware XR300
Hello, I came across a firmware update on the website for the xr300 which my xr300 doesnt pick up when i try to update it with the nighthawk app. So i tried using the manual to manually update the fi...
Netduma-Fraser
Aug 18, 2021NetDuma Partner
You'll need to access the interface using a PC to go to Settings > Administration > Firmware update, then you can perform an update. What error message do you get when trying to change the language?
