Jerome_w
Aug 18, 2021Tutor
Updating Firmware XR300
Hello, I came across a firmware update on the website for the xr300 which my xr300 doesnt pick up when i try to update it with the nighthawk app. So i tried using the manual to manually update the fi...
Netduma-Fraser
Aug 19, 2021NetDuma Partner
Refresh the page, then skip the update part and you should be able to get to the interface. Then can you take a screenshot of the Settings page on the Administration section please
Jerome_w
Aug 19, 2021Tutor
Ok, after rebooting I can now change the language to english , and there in the menu it does have the update firmware option. I guess its just a glitch within the dutch language
- Netduma-FraserAug 19, 2021NetDuma PartnerGlad to hear it, thanks for the update!
- StamerDec 27, 2021Aspirant
Hi!
I also have this problem and cant seem to find the Admin panel.
I had my language on (Swedish) and the admin panel was missing.
Changed to English and the panel is there.
Maybe you should fix that bug.- Netduma-FraserDec 27, 2021NetDuma PartnerI'll pass it on to the team at Netgear, thanks for the report.
