nicey1958
Mar 09, 2023Guide
upgrade from 500 to xr 1000
title says it. Is it worth it or is it just for wifi 6? cheers
- Mar 27, 2023
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Mar 09, 2023Guru - Experienced User
Up to you. If you don't have any WiFi6 supporting device, may wanna wait for WiFI7. No idea when that will appear for sale.
