nicey1958
Mar 09, 2023Guide
upgrade from 500 to xr 1000
title says it. Is it worth it or is it just for wifi 6? cheers
- Mar 27, 2023
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
nicey1958
Mar 26, 2023Guide
970mbps down/120 up is my internet connection. i adjusted bandwidth for the devices that seem to suffer buffering occasionally... sky minibox and the shield (both wired to upstairs -. via a magic 2 extender (i was thinking that might be one cause.. but its been fine in the past) because they both suffer if I use the boxes them wireless as well. I keep trying in the meantime.
cheers
Netduma-Fraser
Mar 26, 2023NetDuma Partner
Don't adjust the bandwidth, that won't get rid of the lag, its Congestion Control you'll want to change specifically. Start at 70% and experiment in increments of 10%
