nicey1958
Mar 09, 2023Guide
upgrade from 500 to xr 1000
title says it. Is it worth it or is it just for wifi 6? cheers
- Mar 27, 2023
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
nicey1958
Mar 26, 2023Guide
done.
cheers
Mar 27, 2023Guru - Experienced User
Enjoy. 📡
