niewiado
Oct 28, 2022Apprentice
Upgrade from xr500 to xr1000 PS5 Console issues
Hello all. I’ve been using my xr500 for a while with no issues (finally), but the resets have been becoming more necessary recently to keep it connected to the internet so I upgraded to the xr1000. ...
Oct 28, 2022Guru - Experienced User
If your noticing similar problems across two different model routers, possible you have a mis configuration or environment problem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How do you have Wireless settings under Basic and Advanced configured?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
I'm using channel 1 and 40 with AX, OFDMA, Beamforming and MIMO all enabled. 40Mhz coexistence only on 2.4Ghz on my 1000.
- niewiadoOct 28, 2022ApprenticeIt updated to the latest .64 on the xr1000 when I installed it. The xr500 hasn’t had a firmware update in a while but it’s the latest as well.
I had all my settings the same as you below but I also tried disabled ax features. I left the xr1000 in auto mode (and lowered the 5ghz bandwidth to enable that) but I routinely use a network analyzers and funnily enough it picked the exact same channels I had for the xr500, namely 36 for 5 ghz which is the problem channel.
I just reinstalled the xr500 with the same channel and all my previously mentioned problems went away. iPhones connect to 5ghz with over 500 Mbps down (I get around 780 at the modem) and the ps5 connects immediately and has around 400 Mbps down from its internal test.
Also- I’m using the same netgear cm600 modem I’ve always had with my Comcast cable IP in the states.
Thanks- FURRYe38Oct 28, 2022Guru - Experienced User
This is what I get on my iphone with the XR1000:
Using channels 1 and 40.
Router was factory reset and setup from scratch after I applied v.64 FW.Mines connected to a CAX80 on a 1Gb/50Mbps ISP line.
