niewiado
Oct 28, 2022Apprentice
Upgrade from xr500 to xr1000 PS5 Console issues
Hello all. I’ve been using my xr500 for a while with no issues (finally), but the resets have been becoming more necessary recently to keep it connected to the internet so I upgraded to the xr1000. ...
niewiado
Oct 29, 2022Apprentice
iPhones typically get 400-550 Mbps depending on where they are in the house. They never seem to need to downgrade to 2.4ghz. 2017 Lg tv doesn’t seem to be able to bind channels so YouTube usually connects at around 100 Mbps. Xbox and ps5 usually get 200-350 Mbps, sometimes more. These are all speeds from the xr500, which I’ve switched back to for the time being.
Netduma-Fraser
Oct 29, 2022NetDuma Partner
Are you using Armor at all? That is one of the big differences between the two models and Armor has caused some issues in the past.
- niewiadoOct 29, 2022ApprenticeI didn’t turn anything off so I think it is enabled yes. I didn’t see anywhere to turn it off.
- Netduma-FraserOct 30, 2022NetDuma PartnerYou'll need to use the Nighthawk app on your mobile and then you can turn it off from there
- niewiadoOct 31, 2022ApprenticeHi Fraser, I finally got a chance to disable armor and it didn’t really help the ps5 connection. It still does not want to connect with the same possible security setting warning. I’m pretty close to returning the xr1000. Any last ideas?
- Netduma-LiamNov 01, 2022NetDuma Partner
Could you please go to Settings -> Setup -> LAN Setup and try reserving an IP address for the PS5. Ideally, give it an address that's outside of the DHCP range, you can see what this is a bit further up in the page.
After that, see if it can maintain a connection after a reboot.
- FURRYe38Nov 01, 2022Guru - Experienced User
Does the PS console connect ok using a ethernet connection to the XR1000?
Possible that the PS console wifi device could be faulty. I've seen some consoles not have good wifi devices or connect or operate well over there wifi adapters.
- niewiadoNov 01, 2022ApprenticeI haven’t tried that, but besides not really being a long term option, the xr500 connects to the ps5 flawlessly with an almost constant 100% signal strength (it’s directly above the console).
This applies to the static IP suggestion as well- the xr500 didn’t need this but I can try it. - Netduma-FraserNov 01, 2022NetDuma PartnerChange NAT to Open in WAN Settings and then re-test as well please and see if there is a difference
And you set XR1000 wifi settings to same as XR500?
Disable AX mode on the 1000 router as well?
This applies to the static IP suggestion as well- the xr500 didn’t need this but I can try it. - niewiadoNov 01, 2022ApprenticeHello all. So I went into wan settings and set NAT to open (xr500 was secured the whole time) and I went into the lan settings and gave the ps5 a static IP address outside the DHCP range (xr500 also never had this) and this didn’t seem to help.
I also made sure to the other settings matched as much as I could tell. Then I disabled port scan and DoS protection and set my IPv6 to auto detect which is what the xr500 had and confirmed armor and Adblock were both disabled.
The only thing that helped was turning AX features off. This immediately caused the ps5 to connect.
However, upon restart or going to sleep and waking back up (didn’t matter which) the connection was lost. Then I turned AX features back on and without any ps5 restart it reconnected to the network right away but again- did not remain connected after a restart.
So I can routinely get it to connect now but unfortunately not to stay connected. When connected it benchmarks faster than the xr500 which is great and QoS seems to work well but I can’t turn the ps5 off lol. Any last ditch ideas?!
Thanks for all the help guys, I do appreciate how prompt you are to respond but I’m starting to lose faith in my upgrade here. - Netduma-LiamNov 02, 2022NetDuma Partner
Out of interest, can you completely disable QoS from the three-line menu in Congestion Control, then see if you can replicate the issue? I know it sounds unrelated, but it may be something to do with the DPI engine.
Also, do you have any rules setup in Traffic Controller? If not, can you try adding one to Allow the PS5 at all times?
- niewiadoNov 02, 2022ApprenticeHello all-
So the QoS disabling and the traffic rule to always allow the ps5 didn’t change anything. However, I did finally find a setting that allows me to restart while connected.
It turned out to be smart connect.
Now on the xr500 it’s enabled as I mentioned before with no issue on the ps5, so I have the ps5 set to only connect to 5ghz. And like I said before the signal strength is usually near 100% if not 100%. However being wireless it can fluctuate down to the 90’s occasionally.
When I turned smart connect off on the xr1000 and kept the 5ghz ssid the same name it was able to stay connected after a restart. Furthermore, when I set the ps5 back to “automatic” band selection and then turned smart connect back on the ps5 connected after a restart but always to 2.4ghz. So for whatever reason it forces the ps5 to reconnect to 2.4 after a restart with smart connect enabled.
I suppose if one of wifi 6’s benefits is improved 2.4 connections it’s not the end of the world, but you would think a signal strength above 90% would default to 5ghz. Interestingly, playing a bit of CoD MW2 on 2.4ghz on the PS5 after all this did seem to reduce some packet loss but I’m not sure if that was a transient thing or not.
Also I think it’s worth mentioning I have a series x as well and it connected to 5ghz just fine every time I checked, although some in game NAT types went from open to moderate.
Any thoughts on any of this?
Thanks again - Netduma-LiamNov 03, 2022NetDuma Partner
That's interesting, so it must be something to do with the PS5's WLAN adaptor and how SmartConnect recognises this. That's a tricky one for us as SmartConnect is a NETGEAR feature and we don't really have anything to do with it's development as part of the Netduma team.
It's possible that 2.4Ghz could reduce any packet loss you experience, that would also suggest that the signal strength on 5Ghz is not quite as strong as the PS5 seems to think it is though.
You could perhaps improve this further by looking at a Wi-Fi Analyser again and ensuring you're on the least congested channels, that would help with 5GHz particularly.
- niewiadoNov 08, 2022ApprenticeHello all-
So I left the xr1000 connected for the weekend and things worked alright for the most part, but I discovered yesterday that the Xbox no longer recognizes ipv6. A quick search showed that this is not an isolated issue and the very moderators here in this thread have even helped troubleshoot this in the past.
From what I could tell, at the time it was hoped a firmware update would fix this, but these are dictated by NG’s schedule, not Netduma. What’s funny is even though these updates do not appear to come to us very often, maybe a couple weeks before I purchased my xr1000 a new firmware update did finally come through to us if I understand that correctly.
Does this basically mean it’s still not a fixed issue? This may be the final straw to have me return the router. In the meantime I reconnected the xr500 and immediately
A) ipv6 returned to Xbox
B) ps5 left on automatic channel selection still connected to 5ghz with 100% signal strength
C) iPhones in the house always connect to 5ghz, albeit at slightly reduced speeds
I adopted the xr500 early on and was part of the beta program so I know it took a while to get all the bugs ironed out there (for the longest time I would miss calls as my cellular connection isn’t great in the house and WiFi calling wouldn’t work) but eventually the xr500 came to be the absolute best router I’ve ever owned, both for gaming and wfh through the pandemic. I hoped the xr1000 would just be that with the added throughput and congestion control of wifi 6, but maybe it too just needs more time to work through the bugs. - Netduma-FraserNov 08, 2022NetDuma PartnerWe have a big update coming for the 1000 which shouldn't be too much longer so I would recommend waiting until then and I feel a lot of your issues should be resolved.
- niewiadoNov 08, 2022ApprenticeI do have a return window I need to abide by. Any idea how much longer?
- Netduma-FraserNov 08, 2022NetDuma PartnerI don't have a timeline but you can keep up to date with the firmware progress here: https://support.netduma.com/en/support/solutions/articles/16000132677-dumaos-firmware-progress
- niewiadoNov 09, 2022ApprenticeHi Fraser-
I looked into it and I have an extended holiday return window from Best Buy so I guess I can hang onto the 1000 for a while.
I did plug it in earlier today to check for a firmware update and left it connected to play some CodMW2 on the ps5. It connected to 5ghz initially but it crashed my game a few minutes in as it lost connection. I reconnected to 2ghz and while it stayed connected I had 3 consecutive games in different modes with very bad ping spikes that induced noticeable rubber banding. I changed the game modes and made sure to play more than one game to notice a pattern. I then switched back to the xr500 and all the lag went away.
I also used the Netduma app while gaming and while connected to the xr1000 the qos did not detect high priority packets. While connected to the xr500 it did detect them.
I really hope all these issues are addressed when this new firmware update drops because it’s quite a list at this point. I don’t think I’ll connect it back until this firmware drops so will that last link you sent me tell me that netgear has approved it and passed it on to us? - Netduma-LiamNov 10, 2022NetDuma Partner
There will be a DPI update coming out soon which you should receive over the air, that should improve the detection of CoD in QoS.
Do you still have QoS disabled on the XR1000 as per my last advice or have you since set it up again?
- niewiadoNov 10, 2022ApprenticeI’ll have to double check but yes I believe I have QoS reenabled. I also have ax features enabled, smart connect enabled, auto detect ipv6 enabled- all things I was either told to try at one point in the past or are currently giving me issues.
Only setting I think I kept was up to 2400mbps channel bonding on the 5ghz bands. - Netduma-LiamNov 10, 2022NetDuma Partner
Did we not find that SmartConnect was causing the problem? If you disable it again do you still have the same issues.
- niewiadoNov 10, 2022ApprenticeSo I forced the ps5 to only connect to 5ghz before. When I set it to automatic it normally just connects to 2ghz which isn’t ideal but I want to leave smart connect on since everything else in the house is set to the same ssid but some devices only can connect to 2.4 ghz. It’s just a feature that worked on the xr500 and I’d like to keep using.
- Netduma-FraserNov 10, 2022NetDuma PartnerThere will be a new update soon but in the meantime you could setup guest WiFi just for the console
- niewiadoNov 10, 2022ApprenticeI suppose I can try that. Will QoS apply to guest networks? Can I try making a QoS rule that just prioritizes all ps5 traffic which applies to a guest network?
Also, do you have reason to believe that the ipv6 issue with Xbox’s will be addressed with this upcoming firmware update? - Netduma-FraserNov 10, 2022NetDuma PartnerI don't think guest devices show up on Device Manager, either way QoS applies to the whole network. I wouldn't advise it, if there is a download that would cause a lot of lag. IPv6 is something we've been paying attention to so I'm confident it should be a lot better in that regard.
- niewiadoNov 10, 2022ApprenticeWhat about adding the ps5 as a device to the traffic prioritization? Are you saying it’s just best to leave it on DumaOS classifies games only?
