EurynomeStolas
Feb 26, 2019Guide
Upgraded from netduma to xr500 for faster speeds ...
Why is it such a struggle to just plug a router in and get the 1000down/up your isp is giving you. I spent $200 on netduma now $300 on xr500 I feel like I am literally getting hosed hard. I have cm10...
- Mar 01, 2019
It would be preferred to have the XR wifi on the main level however if it has to be in the basement, then disable it's wifi radios and use the R8000s wifi in AP mode if it can be up on the main level. I would disable the X4 upstairs as well and see if the wifi from the R8000 in AP mode is sufficient for wifi upstairs.
Feb 26, 2019Guru - Experienced User
Speed testings wired with the cable modem first. Then wired with the XR router while nothing else is connected?
Did you walk thru the setup wizard when connecting it to the cable modem and you power cycled the cable modem as well?
What FW version is loaded on the XR500?
The max you'll see out of any 1G supporting router and capable PC is 900Mb + or -.
- Netduma-FraserFeb 26, 2019NetDuma PartnerHave you put your expected speeds into the Anti-Bufferbloat bandwidth options? Are you running a wired speed test as well?
If you're using QoS you'll remember from the R1 that it'll throttle your speeds so after making sure you've entered the correct speeds make sure Anti-Bufferbloat is set to never and 100% then run the wired speed test.- EurynomeStolasMar 01, 2019GuideMy biggest issue is that the internet works fine. Then WiFi keeps getting dropped and the wife is 😡. I was wondering if I have a r8000 in ap mode then the xr500 has to use the same MAC address as the r8000 does that mess with the network that they have the same MAC address? I just want to get this working. I get home and run me run the setup wizard and I will have internet on wired devices but not WiFi.
- FURRYe38Mar 01, 2019Guru - Experienced User
MAC addresses should not be the same on any network.
If you have the R8000 is AP mode, then you should disable the wifi radios ON the XR router unless you have a good distance between the XR and R router, 30-40 feet to start and you use manual channels on each farthest channels away from each other on 2.4Ghz and 5Ghz.
